upgrade 6000/M3 to 7200
  • 1.  upgrade 6000/M3 to 7200
    Posted Nov 10, 2014 06:26 PM
    We currently have 3 controllers. 1 act as a master and no AP's terminate to this. This current setup sevice around 400 AP's using AOS 6.3.1.6. Now, we received two 7200's and we want to replace the current 3 controllers to just 2 7200's. Below is a sketch on how our network is setup and how we want it when we upgrade.
    Now, I think we have all the information how to replace 1 controller to 1 controller but replacing it by 2 controller to 1 controller is still hazy. Here's our method for 1 to 1:
    Aruba Controller Migration Steps.
    1)	Back up flash
    •	We have old backups but we’ll do another backup on the day of the upgrade.
    2)	Update existing Controllers to Aruba OS 6.3.x or 6.4.x
    •	Existing Controllers are version is 6.3.x
    3)	Update the NEW 7200 controllers to have the same version of Aruba OS loaded in the existing controllers. This is important so that we can load back the flash backup.
    •	Still needs to be done.
    4)	Transfer ALL existing Licenses to the new controller that will be assigned as the new Master.
    •	Using License Management Server (LMS) at https://licensing.arubanetworks.com
    5)	Stage new 7200 Controller.
    •	Mount and connect all necessary interfaces
    6)	Install transferred licenses on the  NEW 7200 controller.
    •	Don’t reboot or save.
    7)	Backup newly installed licenses.
    •	Keep this because we will load these again.
    8)	Install the backed up data to the new 7200 controller using “restore flash” command.
    9)	Install transferred/backup/new licenses from step 7.
    •	New controller should be rebooted the first time.
    •	Do not save config or write memory
    10)	Update interface configuration and change the hostname
    •	Update trust ports.
    11)	Confirm that new controller operates as expected.
    So from the steps above, we should be able to replace the old master to the new 7200 master with no hiccup on the network. This is because, even the master is out on our current setup, the network still works.
    Now the puzzle is, how are we going to proceed in replacing the 2 local controllers to 1 local.
    I would love to hear suggestions, corrections, tips and tricks.
    Thank you.
  • 2.  RE: upgrade 6000/M3 to 7200
    Posted Nov 10, 2014 07:59 PM
    If you are planning on keeping the same config then you should the future master as a standby master to the M3 and the future local as a local to the M3
    Once you have configured all the necessary VLANs and apply all the licenses then you can move all the APs to the new local and switch the VRRP priority to be higher on the future Master (7200)
    To do this all your controllers need to be on the same AOS
