Upgrade 6.x (Master - Local) to 8.x - Licensing?
  • 1.  Upgrade 6.x (Master - Local) to 8.x - Licensing?
    Posted Apr 09, 2019 03:21 PM
    I need to upgrade two 72xx Controllers to Version 8.x. At the moment they are running in Master-Local mode with Version 6.5.3.3.
    Is it possible to convert the existing Per AP Capacity & PEF licenses to Virtual Mobility Master and add two MC's? Or do I need to buy VMM capacity licenses?
    If not, the only other option would be to install two Standalone MC's, because with MCM + MC I wouldn't have redundancy, right?
    Thank you ;)
  • 2.  RE: Upgrade 6.x (Master - Local) to 8.x - Licensing?
    Posted Apr 09, 2019 06:06 PM
    You can transfer the existing AP, PEF and RFP license to the VMM but in order for you the manage the APs and MCs vía the VMM , you need MM License = # of MCs + # of APs
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
