Upgrade 7210 to ArubaOS 8.x - Mobility Master and masterip
  • 1.  Upgrade 7210 to ArubaOS 8.x - Mobility Master and masterip
    Posted Jan 29, 2019 03:56 PM
    I have four 7210 controllers - 2 are less than a year old - these two have no problem connecting to MM. MM localip configured as 0.0.0.0.
    MM localip 0.0.0.0
    masterip: 172.22.2.20 - VRRP
    MM-0 ip:172.22.2.100
    MM-1 ip 172.22.2.101 . vlan1
    7210 ip 172.22.5.15 .  VLAN5
    The other 7210s are five-years old. Configured as Master/Local - upgraded just the local from 6.5.4.10 - to 8.x . Cannot connect to MM VRRP or MM static addresses. I tried many 8.x versions.
    From the 7210, I can ping the masterip gateway MM-0 and 1. Regardles of the masterip value, I cannot ping. I moved these three addresses, 172.22.2.0/24 around with one another. I can ping them all, provided it's not the masterip.
    I tried PSKwithIP and PSKwithMAC
    I also tried with the controller ip on the same subnet as the masterip.
    I recreated the localip 0.0.0.0. I also created a localip specific to the controller.
    Using 'show datapath session' on the controller, I do see the controller attempting to connect on port 8211. "show crypto ipsec sa" is empty.
    "show ip route" displays the masterip: C 172.22.2.20/32 is an ipsec map default-local-master-ipsecmap
    Has anyone seen this behavior?
    TIA
    Greg Crockett
  • 2.  RE: Upgrade 7210 to ArubaOS 8.x - Mobility Master and masterip
    Posted Jan 29, 2019 05:12 PM
    To connect a controller to an MM, you need to do a "write erase all" and connect it to the MM using the startup dialog.  You cannot just execute "masterip".
  • 3.  RE: Upgrade 7210 to ArubaOS 8.x - Mobility Master and masterip
    Posted Jan 29, 2019 06:05 PM
    I did 'write erase'. Plus, I used the following from /mm/mynode with 'disaster-recovery on':
    masterip 172.22.2.20 IPSec xxxxxxxx interface VLAN x.
    the controller will reboot automatically.
  • 4.  RE: Upgrade 7210 to ArubaOS 8.x - Mobility Master and masterip
    Posted Jan 29, 2019 06:21 PM
    If you have not already, please contact TAC.  It is hard to say from here what could be wrong.  You could have a bug.
  • 5.  RE: Upgrade 7210 to ArubaOS 8.x - Mobility Master and masterip
    Posted Jan 29, 2019 06:40 PM
    Thanks. Just opened TAC.
  • 6.  RE: Upgrade 7210 to ArubaOS 8.x - Mobility Master and masterip
    Posted Jan 29, 2019 08:07 PM
    The contents set in mm / mynode are as follows
    localip 0.0.0.0 ipsec ******
    Register md group below md
    In md, md will automatically reboot when set as below.
    masterip 10.10.30.xx ipsec ****** interface vlan 30
    If you set up local-master interworking, it will not ping until interworking is completed.
    If it does not work, you may need to reset md after initialization.
  • 7.  RE: Upgrade 7210 to ArubaOS 8.x - Mobility Master and masterip
    Posted Mar 19, 2019 09:19 PM
    I ran into a similar issue while lab testing a 7010 upgraded from 6.x to 8.4.
    I initially just "wr erase" the 7010 and configured through the full-setup wizard. I configured the controller from MM and added the 7010 as a managed device. After initially joining the MM the controller kept losing conectivity, stayed in CONFIG ROLLBACK state, lost connectivity and kept rebooting after a few minutes up. I then did a "wr erase all" and started the process again. Problem fixed.
    Thanks for your help!
  • 8.  RE: Upgrade 7210 to ArubaOS 8.x - Mobility Master and masterip
    Posted Jan 31, 2019 12:56 AM
    The fix: do not mix firmware. I had FIPS on the MM and non-FIPS on controller.
    all is fine.
    greg
