Upgrade 8.2 - supported AP
  • 1.  Upgrade 8.2 - supported AP
    Posted Jun 04, 2018 09:37 AM
    Hi all,
    I have two Mobility Controller 7210 v 6.5.3.2 in HA Active/Standby and some AP103, AP105 and AP135 managed from the controller.
    The customer would like to upgrade the controllers to AOS 8.2.
    It is possible or the APs managed are not longer supported in AOS 8.2.?
    If yes, can you tell me please wich models are not longer supported?
    thanks a lot
    kind regards
  • 2.  RE: Upgrade 8.2 - supported AP
    Posted Jun 04, 2018 09:44 AM
    All the 8.x the release notes have a "supported controllers" and "supported access points" section.
    Attachment(s)
  • 3.  RE: Upgrade 8.2 - supported AP
    Posted Jun 04, 2018 09:53 AM
    Thanks for the fast reply,
    I've already read the release notes, but I didn't understand if AP-103 are supported or not. I think yes, I would like to have just a confirm about that.
    thanks a lot
  • 4.  RE: Upgrade 8.2 - supported AP
    Posted Jun 04, 2018 10:25 AM
    The AP-103 is in the supported chart.  Does the fact that there is a dash in the "family" column make it confusing?
  • 5.  RE: Upgrade 8.2 - supported AP
    Posted Jun 04, 2018 10:27 AM
    For me, absolutely yes
  • 6.  RE: Upgrade 8.2 - supported AP
    Fair enough.  We will raise this as an issue.
  • 7.  RE: Upgrade 8.2 - supported AP
    Posted Jun 04, 2018 10:32 AM
    The AP-103 is supported on the version of code mentioned above, and in the release notes posted.
  • 8.  RE: Upgrade 8.2 - supported AP
    Posted Jul 02, 2018 07:52 AM
    In the 8.2.1.x and the 8.3.0.1 release notes, the Documentation Team changed the format of the Supported AP Platforms and removed the dashes.  I hope this makes it more clear:
