Network Management
Upgrade AirWave from v7.6.3 to v7.6.4
  • 1.  Upgrade AirWave from v7.6.3 to v7.6.4
    Posted Jun 19, 2013 02:55 PM
    Are there any guides/manuals to describe upgrading from AirWave v7.6.3 to v7.6.4? I have checked the Aruba Support site and have not found anything that would help with the upgrade. Are there any specific steps to follow for the upgrade?
  • 2.  RE: Upgrade AirWave from v7.6.3 to v7.6.4
    Posted Jun 19, 2013 04:10 PM
    Two options for upgrading based on network connectivity:
    If your AMP can reach the internet, then you can use the automated method:
    # start_amp_upgrade -v 7.6.4
    This will then prompt you for your support account username and password.
    If your AMP can't reach the internet directly, you can use the manual method:
    1. Login to support.arubanetworks.com
    2. Download AirWave upgrade package from Download -> AirWave -> AMP -> current version -> 7.6.4
    3. Upload into /root (WinSCP is a common tool used for transferring from Windows to AMP)
    4. Initialize the upgrade
  • 3.  RE: Upgrade AirWave from v7.6.3 to v7.6.4
    Posted Jun 19, 2013 05:46 PM
    Key point, before initializing the upgrade, change directories to /root so you're not in the directory getting upgraded.
    Also, if you're upgrading over ssh, run screen first so a disconnected session won't break everything.
  • 4.  RE: Upgrade AirWave from v7.6.3 to v7.6.4
    Posted Jun 20, 2013 10:57 AM
    We had an upgrade issue one time, and we were advised to clear the RRD cache prior to the upgrade.
    I don't know that it is neccesary everytime, but I usually clear the RRD cache prior to the upgrade. It's become like rubbing the rabbit's foot.
    Clearing the RRD cache
    # rm -rf /var/airwave/cache/rrdcached/rrd.journal*
    # rm -rf /var/lib/airwave/cache/fastmmap/awrrdtool_write_cache
    # service rrdcached restart
  • 5.  RE: Upgrade AirWave from v7.6.3 to v7.6.4
    Posted Jul 02, 2013 03:43 PM
    Rob,
    Why isn't their any upgrade procedures in the documentation, just like it is when upgrading the Aruba Wireless Controllers?  Could this be added?
  • 6.  RE: Upgrade AirWave from v7.6.3 to v7.6.4
    Posted Jul 02, 2013 03:52 PM
    Good idea.  I'll see what I can do.
