Upgrade AOS 6.2.1.4 connect wifi slowly
  • 1.  Upgrade AOS 6.2.1.4 connect wifi slowly
    Posted Nov 25, 2013 02:26 AM
    last week i upgrade Consumer AC OS 5.0 to 6.2.1.4 . today they tell me that conncet the wifi with Captive portal slowly than before,so i want know why?and what can i do to make it faster.
  • 2.  RE: Upgrade AOS 6.2.1.4 connect wifi slowly
    Posted Nov 25, 2013 08:58 AM
    If it's only a matter of captive portal -  (Guest network)
    Check this out:
    (Aruba3600) #show web-server
    Web Server Configuration
    Parameter                                      Value
    Cipher Suite Strength                          high
    SSL/TLS Protocol Config                        sslv3 tlsv1
    Switch Certificate                             default
    Captive Portal Certificate                     default
    Management user's WebUI access method          username/password
    User session timeout <30-3600> (seconds)       900
    Maximum supported concurrent clients <25-320>  25
    Enable WebUI access on HTTPS port (443)        false
    Try to Increase that number.
    (Aruba3600) (Web Server Configuration) #?
    captive-portal-cert     Certificate name configured under certificate
                            manager
    ciphers                 Configure cipher suite strength. Default is high
    mgmt-auth               Configure management user's WebUI access method,
                            either username/password authentication or
                            certificate authentication or both. Default is
    no                      Delete Command
    session-timeout         Configure user's WebUI session timeout <30-3600>
                            (seconds)
    ssl-protocol            SSL/TLS Protocol Config
    switch-cert             Certificate name configured under certificate
                            manager
    web-https-port-443      Enable WebUI access on HTTPS port (443)
    web-max-clients         Configure web servers' maximum supported concurrent
                            clients <25-320>
    (Aruba3600) (Web Server Configuration) #web-max-clients
    In addition, you could:
    - Make sure you have "Drop Broadcast and Multicast" enabled on all of your Virtual APs
