Upgrade AP105 TFTP error: 'File not found' (1)
  • 1.  Upgrade AP105 TFTP error: 'File not found' (1)
    Posted Dec 18, 2013 09:54 PM
     We have a problem that a ap-105 wireless ap can not connect to aruba controller.
    Here is error message on ap-105 console.  What is something wrong?
    Filename 'mips32.ari'
    Load address: 0x2000000
    Loading: "
    Giving up...
    apboot>
    Here is aruba information.
     (Aruba800) #show version
    ArubaOS (MODEL: Aruba800), Version 2.5.4.6
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2006, Aruba Wireless Networks
    Inc.
    Compiled on 2007-01-17 at 20:58:07 PST (build
    13954) by p4build
    ROM: System Bootstrap, Version CPBoot 1.1.4 (May
    18 2004 - 15:45:14)
    Switch uptime is 3 months 4 days 11 hours 44
    minutes 12 seconds
    Reboot Cause: User reboot.
    Supervisor Card
    Processor (revision 16.20 (pvr 8081 1014)) with 256M bytes of memory.
    32K bytes of non-volatile configuration memory.
    256M bytes of Supervisor Card System flash
    (model=CF 256MB).
  • 2.  RE: Upgrade AP105 TFTP error: 'File not found' (1)
    Posted Dec 18, 2013 10:03 PM
    The AP-105 requires controller code 3.4 or higher. Looks like you are running 2.x
  • 3.  RE: Upgrade AP105 TFTP error: 'File not found' (1)
    Posted Dec 18, 2013 10:21 PM
    I will try to upgrade Aruba OS and check this situration.
    Thanks for your information.
