Upgrade Aruba 7005 OS
This thread has been viewed 53 times
  • 1.  Upgrade Aruba 7005 OS
    Posted Mar 31, 2020 01:28 PM
    I have an Aruba 7005 Controller running ArubaOS v6.5.1.4 and I want to upgrade it to v8.4 or higher. Where do I get the OS file to upgrade it?
    I've looked through this site and Googled, but only finding instructions on how to upgrade it, but not the actual file.  If i have to pay for it, that's no problem, just don't know where to get it.
    Any help would be greatly appreciated!
    Thanks!
    Jim
  • 2.  RE: Upgrade Aruba 7005 OS
    MVP
    Posted Mar 31, 2020 02:44 PM
    You need to have a support contract in order to access to the requested Files.
    However, i would recommend to get the file officially from:
    https://support.arubanetworks.com/      or
    https://asp.arubanetworks.com/
    File size is more than 200MB so it can't be uploaded here anyway.
  • 3.  RE: Upgrade Aruba 7005 OS
    Posted Oct 22, 2021 09:32 AM
    Can u help me to share the latest firmware aruba 7005 with another way? Maybe using Gdrive or something like that..
    Hengky Po
  • 4.  RE: Upgrade Aruba 7005 OS
    Posted Oct 22, 2021 11:56 AM
    You need to have an active support contract in order to access firmware for the 7005. With that, you can download it yourself through the Aruba Support Portal as it checks that you are eligible to download it. Without a contract, you don't have access to it.
