Hi, trying to upgrade the ArubaOS on a 650 controller. Using TFTP across our management system is not an option so I'm trying to upgrade via USB. I've come across articles stating:
When the controller is then in cpboot> prompt, you can load the image from external USB via
eg. cpboot> bootf 1:1 ArubaOS_6xx_6.3.1.12_46311
How do you tell the controller were the external USB drive is located? i.e. what does 1:1 mean - which is the usb?
I've got a 650 on my desk and I'm connected to it via console cable with the USB plugged directly into the controller (a lab setup to test before production changes). I'm having no luck at all. Is USB all functionality removed as part of ArubaOS 6.x ?
Is what I'm trying todo even possible?
