Upgrade ClearPass cluster from 6.6.8 to 6.7.1 - best path?
  • 1.  Upgrade ClearPass cluster from 6.6.8 to 6.7.1 - best path?
    Posted Feb 27, 2018 12:30 PM
    I normally upgrade in lockstep with releases so I seldom have to work out a best path, but due to nerves about changes during the holisays and the new licensing model etc. I've got choices.
    We're running two servers (publisher/subscriber) on 6.6.8
    I have a patch to 6.6.9 and two which lead to 6.7.0 (I presume 6.7.1 becomes available after 6.7.0 is in place)
    Should I bother with 6.6.9 or just go to 6.7.0?
    When I got to 6.7.0 it looks like I should run the Cluster Interface patch first and then upgrade the cluster, it that right?
    Will 6.7.1 magically show up as available once I'm done with this round?
  • 2.  RE: Upgrade ClearPass cluster from 6.6.8 to 6.7.1 - best path?
    Posted Feb 27, 2018 02:16 PM
    I would take the following path in your environment:
    - Upgrade Publisher directly from 6.6.8 to 6.7.0 (6.7.1 will show up in updates after 6.7.0 is up and running)
    - Install interface upgrade patch (if required for your environment, check release notes to confirm)
    - Upgrade subcriber to 6.7.0
    - Install interface upgrade patch (again, only if required)
    - Upgrade Publisher to 6.7.1
    - Upgrade Subscriber to 6.7.1
     Also, follow other best practices; ie. backup before upgrade, plan downtime accordingly, etc.
  • 3.  RE: Upgrade ClearPass cluster from 6.6.8 to 6.7.1 - best path?
    MVP
    Posted Feb 27, 2018 02:40 PM
    I have not yet upgraded to 6.7 in Production but remember the licensing has changed for 6.7+
    I will likely get advice from TAC before I upgrade. to insure things go smoothly.
  • 4.  RE: Upgrade ClearPass cluster from 6.6.8 to 6.7.1 - best path?
    Posted Feb 27, 2018 02:50 PM
    Thanks Bruce
    I didn't mention it, but I've already got the license worries ironed out (I hope) we should be good on that front.
  • 5.  RE: Upgrade ClearPass cluster from 6.6.8 to 6.7.1 - best path?
    MVP
    Posted Feb 27, 2018 02:53 PM
    Great!
    It is always better to be safe than sorry. I will probably upgrade my 5 25K appliances to 6.7.x this summer.
    EDIT: I do not use the cluster upgrade tool in my environment. The servers are behind a load-balance switch so I can take them offline individually without impacting services.
  • 6.  RE: Upgrade ClearPass cluster from 6.6.8 to 6.7.1 - best path?
    Posted Feb 27, 2018 06:47 PM
    Being VMs makes me a bit cavalier - just snapshot, test and rollback if there's any issue.
    That said, I took two reposnses as "no reason to stop" and hit the cluster upgrade buttons. (after snapshots were made in VMware)
    About an hour-and-a-half later they sers done. I watched both servers activity trackers as auth-requests moved back then forth.
    All appears well and upgraded.
    If there's no smoke in the morning, I'll update to 6.7.1.
    Wish me luck!
  • 7.  RE: Upgrade ClearPass cluster from 6.6.8 to 6.7.1 - best path?
    MVP
    Posted Feb 28, 2018 07:31 AM
    Kudos & good luck.
  • 8.  RE: Upgrade ClearPass cluster from 6.6.8 to 6.7.1 - best path?
    Posted Feb 28, 2018 07:14 PM
    There were no issues overnight with 6.7.0 so I updated the snapshots and used the cluster update tool to go to 6.7.1 this morning.
    All seems AOK.
    The update took longer than the 6.7.0 upgrade.
  • 9.  RE: Upgrade ClearPass cluster from 6.6.8 to 6.7.1 - best path?
    Posted Feb 27, 2018 02:52 PM
    Thanks Clembo
    I was rather hoping that the magic-cluster-upgrade tool would work as advertised, so I'll probably hit that button and cross my fingers.
    Was hoping to scare up the "wiat, don't touch that!!" folks before I let my curiosity carry me away.
