Hello, I have to do a upgrade to OS 5.0.2.0 to 6.3.1.5.
The upgrade run for 30 minutes.
This is normal?
After the upgrade is started, I have to leave my computer with the image on the network?
Ok, I upgrade to 5.0.4 and after I try to update to 6.3.
It work :)Thank you victorfabian
I have the 7005 Controller, with the 6.4.3.4 OS. Kidnly advise if there is any newer OS to upgrade mine and also how to do that?
Thank you
