Upgrade CPPM from Extension
This thread has been viewed 16 times
  • 1.  Upgrade CPPM from Extension
    Posted Feb 18, 2021 10:40 AM
    Is there a way to upgrade the cluster nodes without using the GUI of ClearPass (I am aware there is no API for upgrading)?
    Akhilesh Shahare
  • 2.  RE: Upgrade CPPM from Extension
    Posted Feb 18, 2021 12:51 PM
    https://www.arubanetworks.com/techdocs/ClearPass/6.8/UpgradingToCP_6.8_TechNote/Default.htm#Upgrade%20Policy%20Manager/Recovering%20from%20a%20Failed%20Upgrade.htm
    we can initiate upgrade from CLI aswell.
    $system upgrade <commad>    for major version upgrade
    $system update  <command>  patch update.
    Pavan Arshewar
    Principal Network Engineer
    If my post addresses your query, give kudos!
  • 3.  RE: Upgrade CPPM from Extension
    Posted Feb 26, 2021 04:13 AM
    But, these commands only allow specific versions to upgrade from/to. I want to fetch the list of available firmware & patch updates (simulating the behavior similar to the GUI).
    1. Is there any other way to achieve this?
    2. Are these APIs intentionally not exposed?
    3. Can we simulate the APIs from GUI?
    Akhilesh Shahare
  • 4.  RE: Upgrade CPPM from Extension
    MVP GURU
    Posted Mar 02, 2021 03:47 PM
    Hi AS70,
    there is not (yet ?) API for this :(
    ACEP / ACMX #107 / ACDX #1281
