Upgrade firmware 6.x to 8.x
This thread has been viewed 27 times
  • 1.  Upgrade firmware 6.x to 8.x
    Posted Sep 29, 2019 10:14 AM
    Hi Guys,
    I'm very new to Aruba, and working on my home lab and I get stuck :) so I hope there are people here that want to help me out.
    Homelab:
    Connect Box (Ziggo) - Ziggo is our home provider
    HP 2530-8G-PoEP Switch (J9774A) - Connected to the Connect Box (Ziggo)
    To the switch I've 1 Aruba controller 7005 and 1 AP-305.
    I try to upgrade the 7005, however through TFPT (GUI and CLI) and local file it is not working. All the time I get the error:
    "Error determining image version."
    I tried with the follow files:
    aruba-mibs_8.1.0.4_61791.tar.gz
    aruba-mibs_8.2.2.6_71606.tar.gz
    aruba-mibs_8.3.0.9_72227.tar.gz
    currently I've ArubaOS 6.5.4.8_65873.
    Try to put my lab up for ACMA/ACMP certification track. Thanks!
  • 2.  RE: Upgrade firmware 6.x to 8.x
    Posted Sep 29, 2019 10:32 AM
    Those files are not upgrade files, but snmp-mib files.
    The file should look something like:
    ArubaOS_70xx_8.5.0.2_71711
    Do you have access to asp? This is a link to the file you need.
    https://asp.arubanetworks.com/downloads/software/RmlsZTphNjYwYWYyYS1iYWY2LTExZTktOGE5My0yYjZiNjQ0ZGZkODE%3D
    Succes!
  • 3.  RE: Upgrade firmware 6.x to 8.x
    Posted Sep 29, 2019 10:42 AM
    Thanks, I was afraid for that. I do have access to ASP, however that file is under entitlement, so no access to that specific file.
  • 4.  RE: Upgrade firmware 6.x to 8.x
    Posted Sep 30, 2019 04:13 AM
    on ASP customers need to add their SAID to be eligble for software downloads. Partners can use the 'partner ready portal user?' link, see attached screenshot.
  • 5.  RE: Upgrade firmware 6.x to 8.x
    Posted Oct 01, 2019 02:01 AM
    Thanks all for the quick replys! Thanks for pointing out the right file :).
    Guess there was something wrong with my account over the weekend, I couldn't download that specific file but since yesterday I was able to!
    The Dutch Aruba team contacted me yesterday by mail as well!
