last person joined: 9 hours ago
upgrade from 5.0.3.3 to 6.1.35
  • 1.  upgrade from 5.0.3.3 to 6.1.35
    Posted Nov 30, 2012 09:03 AM
    Has anyone have any issues with going from 5.0.3.3 to 6.1.35? I will be doing the upgrade in 2 weeks. I just wanted to make sure of an known issues.
  • 2.  RE: upgrade from 5.0.3.3 to 6.1.35
    Posted Dec 03, 2012 03:28 AM
    I have run into a problem where using a local file never completes the upgrade.
    The solution that I have found is to do a 2 step upgrade using TFTP or FTP.  First upgrade to 6.0.x then from there to 6.1.3.x
    That does the trick for me
  • 3.  RE: upgrade from 5.0.3.3 to 6.1.35
    Posted Dec 06, 2012 05:21 AM
    upgrading via ftp seems to have more long term succes then via the browser for me.
    your version just falls in the section that should go to 6.x in one step, but perhaps via latest 5 is safer. do you have any chance to test it?
    and remember about controll plane security
