Upgrade from 6.1.2.7 to 6.1.3.8 Causes Client to behave badly
  • 1.  Upgrade from 6.1.2.7 to 6.1.3.8 Causes Client to behave badly
    Posted Jun 26, 2013 05:10 PM
    So I recently upgrade AOS to 6.1.3.8. Immediately after we began getting complaints that clients connecting using 802.1x  tkip aes are getting disconnected.  I visited the floor and notice that the wireless bars in windows are fluctuations excessively between 5.5 GHz and 300 that is from 1 bar all the way up to 4 bars.   There are no busy channel;   SNR will be 50-40 then suddenly drop down to 17 and lower.   I try adding a AP next to the client and it seems  worked. I move the AP 10 feet away and it started the erratic  behavior again. This an open area with no walls blocking.
    Has anyone notice any similar behavior?
  • 2.  RE: Upgrade from 6.1.2.7 to 6.1.3.8 Causes Client to behave badly
    Posted Jun 26, 2013 09:10 PM
    jmaxwell,
    I would consider upgrading to 6.1.3.9.  There is a fixed bug with WPA-TKIP clients 83776 in the attached release notes.
    Attachment(s)
