Upgrade from 6.1.3.7 to 6.3.1.5
  • 1.  Upgrade from 6.1.3.7 to 6.3.1.5
    Posted Apr 22, 2014 03:10 PM
    Are there any known issues upgrading a 3600 controller directly from 6.1.3.7 to 6.3.1.5? If so, what would be the recommended path to eventually end up on 6.3.1.5?
    Tony
    #3600
  • 2.  RE: Upgrade from 6.1.3.7 to 6.3.1.5
    Posted Apr 22, 2014 03:55 PM
    You should be able to upgrade directly to that code just make sure you read the release notes and do flash backup of your config.
