upgrade from 7.3.3 to 7.4.8 warning
  • 1.  upgrade from 7.3.3 to 7.4.8 warning
    Posted Apr 24, 2012 02:20 PM
    svn: Can't open file '.svn/text-base/Makefile.PG_MAJOR_VERSION.svn-base': No such file or directory
    WARNING: AMP contains patches or modifications to the code
    These changes are likely to be overwritten during the upgrade.
    For additional information please contact Aruba Networks Support at:
    1-800-WiFi-LAN or support@arubanetworks.com
    Would you like to continue with the upgrade? (yes/no):
    Is this a warning I should be concerned with?
  • 2.  RE: upgrade from 7.3.3 to 7.4.8 warning
    Posted Apr 24, 2012 06:03 PM
    Do you know what the patch applied was? it should have provided a list of files that were modified.  If you're unsure if you had a patch applied you can open a support case and have someone check for you.
    Otherwise no, this generally shouldn't worry you and you can continue the upgrade as all affected files will be replaced with updated files as part of the upgrade process.
  • 3.  RE: upgrade from 7.3.3 to 7.4.8 warning
    Posted Apr 25, 2012 01:39 PM
    Thank you for the response. I upgraded the server this morning and everything seems to be fine.
