upgrade-image
  • 1.  upgrade-image
    Posted Jul 24, 2015 08:59 AM
    I'm trying to upgrade the remote IAP205 through CLI.
    Started TFTP-server on 192.168.2.2, it works.
    Then I write the command on IAP205 CLI:
    upgrade-image tftp://192.168.2.2/ArubaInstant_Taurus_6.4.2.6-4.1.1.7_50209
    Answer:
    Upgrading swarm image. Will automatically reboot when done.
    And no effect.
    The TFTP-server doesn't log any connections.
    How to diagnose the problem?
  • 2.  RE: upgrade-image
    Posted Jul 27, 2015 06:31 AM
    It looks like a reachability issue. check the reachability from AP to TFTP server and also the firewall if any existing between AP and TFTP.
