upgrade issues in IAP cluster
  • 1.  upgrade issues in IAP cluster
    Posted Jul 04, 2014 10:15 AM
    Hi all,
    I having issues in upgrading IAP cluster. we are using IAP 105 and it is 14 IAPs in a cluster..
    if we upgrade the IAP from 4.0.0.1 to 4.0.0.5 then it is showing "status is not valid"
    can any one tell me why I am getting this error? is it known issue?
    #ALE
  • 2.  RE: upgrade issues in IAP cluster
    Posted Jul 06, 2014 01:48 AM
    Can you post a screen capture of the screen showing the error? Can you also tell us the complete file name you used for the upgrade?
  • 3.  RE: upgrade issues in IAP cluster
    Posted Jul 07, 2014 06:00 AM
    Hi Marcus
    if I remove one IAP from cluster and upgrade using same image file, then it is working fine
