last person joined: 9 hours ago
Upgrade of 6000 controller to 6.1.3.8
  • 1.  Upgrade of 6000 controller to 6.1.3.8
    Posted Aug 07, 2013 03:32 AM
        I am trying to upgrade a 6000 series with a single M3 from AOS 6.1.3.1 to 6.1.3.8 using the GUI but it is showing an error something like "not supported on this platform". the file I am trying to upload is - ArubaOS_MMC_6.1.3.8_38170.
    Any reason why this might not be working?
  • 2.  RE: Upgrade of 6000 controller to 6.1.3.8
    Posted Aug 07, 2013 07:09 AM
    A. Try to download the image file agian - it might be broken file
    B. Before upgrading clear old unneeded files/backups from the controller
    C. Try to upgrade using TFTP
  • 3.  RE: Upgrade of 6000 controller to 6.1.3.8
    Posted Sep 04, 2013 10:22 AM
    This was overcome by placing the file closer to the device rather than across a VPN. Not sure the exact cause of failure but managed to work around the issue.
  • 4.  RE: Upgrade of 6000 controller to 6.1.3.8
    Posted Jun 11, 2014 10:30 AM
    Any issues after the upgrade?
