Upgrade os image using apboot
  • 1.  Upgrade os image using apboot
    Posted Nov 24, 2013 09:58 PM
    Hi guys,
    How can I upgrade the os image using apboot? what is the command?
    i am upgrading to 7.2.0.
    Thanks in advance.
  • 2.  RE: Upgrade os image using apboot
    Posted Nov 26, 2013 08:28 AM
    What type of AP you are using ??
  • 3.  RE: Upgrade os image using apboot
    Posted Nov 26, 2013 08:04 PM
    Aruba IAP-105.
  • 4.  RE: Upgrade os image using apboot
    Posted Nov 26, 2013 10:32 PM
    I am sorry, the version 7.2 is for Mobility controller and not for the Aruba IAP 105. Now, i don't know where to find the Aruba0S for IAP 105.
  • 5.  RE: Upgrade os image using apboot
    Posted Nov 26, 2013 10:48 PM
    Do you have a support center account? (support.arubanetworks.com)
  • 6.  RE: Upgrade os image using apboot
    Posted Nov 26, 2013 11:21 PM
    I do not have the account for support center.
  • 7.  RE: Upgrade os image using apboot
    Posted Nov 27, 2013 12:45 PM
    Are you not able to access the virtual controller GUI? The GUI will download the upgrade image directly.
    If not, you'll need to either open up a TAC case or contact your SE to get access to the image.
