Upgrade Path: 6.4.2.0 to 6.5.2.0
  • 1.  Upgrade Path: 6.4.2.0 to 6.5.2.0
    Posted Apr 17, 2017 03:08 PM
    Are there any issues jumping from 6.4.2.0-4.1.1.0_45444 to current release 6.5.2.0? They are all 205's. I haven't seen any red flags, but it's always good to check before bricking a couple floors of wireless access for a large number of attorneys.
  • 2.  RE: Upgrade Path: 6.4.2.0 to 6.5.2.0
    Posted Apr 17, 2017 03:19 PM
    I would go ahead and read all of the release notes between your current code to the one you want to upgrade to...  Many, Many changes have been made...
  • 3.  RE: Upgrade Path: 6.4.2.0 to 6.5.2.0
    Posted Apr 17, 2017 03:24 PM
    Also, as a practice, I would not do a major upgrade to a .0 release.  .0 releases typically have features added, so the likelihood for either an issue or a behavior change is increased.
  • 4.  RE: Upgrade Path: 6.4.2.0 to 6.5.2.0
    Posted Apr 17, 2017 03:50 PM
    I'll dial it back to 6.4.4.8 then. Thanks!
  • 5.  RE: Upgrade Path: 6.4.2.0 to 6.5.2.0
    Posted Sep 26, 2017 10:42 PM
    Hi Mate,
    Did you ended up doing the upgrade. I am planning to do the same , moving from 6.4.2.6 to 6.4.4.15 ( as advise by Aruba TAC) .
    the only difference is I have 200 controllers and 1150 access points to do.
    If you have upgraded.., did you have any issue in terms of connectivity/user performance.
    Thanks in advance to everyone ... as always..
  • 6.  RE: Upgrade Path: 6.4.2.0 to 6.5.2.0
    Posted Sep 27, 2017 11:55 AM
    The upgrade went very smooth and took less than an hour for all of them. Yours sounds a little more intense, but I would expect it to go well, too.
    Not a lot in the way of new features for my implementation, but I haven't had to even think about these AP's until you replied to this, so that's something in the way of stability.
  • 7.  RE: Upgrade Path: 6.4.2.0 to 6.5.2.0
    Posted Sep 27, 2017 11:52 PM
    Thanks Mate for replying to my message,
    Yes, you are right. My client is very very political and data sensitive .
    I have to think twice before i make any change
    e.
    Thanks Again,
    Cheers,
