Upgrade path for Aruba Controllers
  • 1.  Upgrade path for Aruba Controllers
    Posted Jun 30, 2017 11:06 AM
    I am tasked to identify the upgrade path to the latest running stable version of AOS. All of the Controllers are running 6.4.4.2 code This is what my inventory: 1 - Master Controller 7210 1 - Local Controller 7210 1 - Local Controller 7010 1 - Local Controller 7030 What will be the recommended upgrade path and to what AOS version? Thank you in advance for your answering my question.
  • 2.  RE: Upgrade path for Aruba Controllers
    Posted Jun 30, 2017 11:34 AM
    You should really only upgrade if you are experiencing a bug, or you need a feature. .
  • 3.  RE: Upgrade path for Aruba Controllers
    Posted Jun 30, 2017 12:34 PM
    Yeah, we'll be deploying 315 AP models throughout the environment and is a requirement as you know. So what is your recommended path?
  • 4.  RE: Upgrade path for Aruba Controllers
    Posted Jun 30, 2017 03:19 PM
    Ho Louis,
    I'd go to the latest one. 6.5.3.1. Have a look into the release notes though. I experienced one bug in 6.5.2.4 running the command aaa test-server .... and it is resolved in this version of code.
  • 5.  RE: Upgrade path for Aruba Controllers
    Posted Jun 30, 2017 04:57 PM
    Thank you, I'll proceed as you are suggesting.
