Network Management
upgrade priority between airwave and aruba os?
  • 1.  upgrade priority between airwave and aruba os?
    Posted Mar 16, 2015 01:58 PM
    I have to upgrade 2 master/local controller and an airwave server.  Is there a risk/preference of upgrading one before the other?
  • 2.  RE: upgrade priority between airwave and aruba os?
    Posted Mar 16, 2015 02:00 PM
    Are you managing your controller config in AirWave?
  • 3.  RE: upgrade priority between airwave and aruba os?
    Posted Mar 16, 2015 02:02 PM
    read-only mode
  • 4.  RE: upgrade priority between airwave and aruba os?
    Posted Mar 16, 2015 03:43 PM
    I typically suggest upgrading AirWave first.  The reasoning is that if the firmware is newer than supported, then you may see some false-positive errors from the AirWave until AirWave system upgrade (depending on what triggers/alerts you have configured).
