Upgrade to 6.2 problems
  • 1.  Upgrade to 6.2 problems
    Posted Aug 19, 2013 02:10 PM
    When I upgraded my 6.1 CPPM to 6.2 via GUI I am gettting this error. it looks like an error with the web page only
    Function updateRowsTableAction() missing
    Has anyone else seen this?
    I can log into guest and CLI no problem and have restarted the services and the VM.
    Any ideas before I revert?
  • 2.  RE: Upgrade to 6.2 problems
    Posted Aug 19, 2013 02:20 PM
    I've upgrade quite a few and haven't seen that issue. Are you using a custom skin or language pack? Please open a TAC case so we can find the root cause.
  • 3.  RE: Upgrade to 6.2 problems
    Posted Aug 19, 2013 07:06 PM
    I would recommend clearing your browser's cache and logging in to the UI again; there might be some stale Javascript code in your browser's cache that is causing the problem.
  • 4.  RE: Upgrade to 6.2 problems
    Posted Oct 02, 2013 08:13 AM
    Did you ever find the fix to this issue?
  • 5.  RE: Upgrade to 6.2 problems
    Posted Oct 02, 2013 10:50 AM
    This is how it was fixed for us.  You probably will want to open a case though.
    [arubasupport@Clearpass1 conf.d]$ sudo vi cppm-access-control.conf
    <Location /tips>
    Order deny,allow
    Allow from all
    </Location>
    <Location /avendaplugins>
    Order deny,allow
    Allow from all
    </Location>
    <Location /tips/servlet/XFireServlet>
    Order deny,allow
    Allow from all
    </Location>
    <Location /tips/services>
    Order deny,allow
    Allow from all
    </Location>
    :q!
    sudo /sbin/service httpd restart
    sudo rm /var/avenda/tomcat/frontend/webapps/tips/js/tipsDwrCombined.js
