Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
  • 1.  Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Jan 19, 2013 09:54 AM
    Have just upgrade an Instant site to this version and now I can't access the GUI.  I am going via another box and port forwarded to port 443.  Initially it throw up the certificate error message, I click continue and then nothing.
    Has something changed in this version?  Is it something similar to the controllers when you connect via https and then it uses port 4343 ?
    Access via ssh is fine.
    Please help.
  • 2.  RE: Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Jan 19, 2013 10:02 AM
    ok, got it.
    changing to port 4343 is exactly what happens.  Change the port forwarding to send to 4343 instead of 443.
    Phewww
  • 3.  RE: Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Feb 27, 2013 10:37 AM
    I have this exact problem after upgrading.. cant log into the GUI.. getting browser not optimized error.. I can access SSH and IP via the GUI.  Where is this port forwarding setting?
  • 4.  RE: Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Feb 27, 2013 11:00 AM
    the port fowarding would only affect you if you get to your IAP via a tunnel or such which doesnt forward port 4343. it isn't a setting on the IAP.
    if you access you IAP normally then this has no effect on you, you just loggin via http://ip:4343/
    getting a browser not optimized error would point to something else, are you using an old or very new browser version? could you show a screenshot of the eror?
  • 5.  RE: Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Feb 27, 2013 11:04 AM
  • 6.  RE: Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Feb 27, 2013 11:05 AM
    using IE8 in normal mode.. getting same error on another machine with IE9
  • 7.  RE: Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Feb 27, 2013 11:10 AM
    weird, and on ip it works? and with a different vendor; firefox, chrome, ...?
    as it is two systems the chance is small but as often with Aruba web gui try clearing cache and try again.
  • 8.  RE: Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Feb 27, 2013 11:12 AM
    Yes, works via IP on IE.. works via IP and DNS via Firefox...
  • 9.  RE: Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Feb 27, 2013 11:18 AM
    clearing cache was the first thing I tried.. no luck
  • 10.  RE: Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Feb 27, 2013 11:19 AM
    might be an issue with the certificate.. Looks like the CN name changed.
  • 11.  RE: Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Feb 28, 2013 10:27 AM
    Anyone know how to fix?
  • 12.  RE: Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Feb 28, 2013 11:04 AM
    I reverted back to
    6.1.3.4-3.1.0.1_35899 and no longer have the issue.. I will not update for now.
  • 13.  RE: Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Feb 28, 2013 03:45 PM
    if it bothers you enough open a TAC case.
  • 14.  RE: Upgrade to 6.2.0.0-3.2 no I can't GUI into Instant
    Posted Feb 28, 2013 03:37 PM
    yep, that's correct.  It is a customers site and I access by port forwarding through a management server.
    I see that error message sometimes as well when I use IE.  Using firefox works fine.
