I try to upgrade to 8.2.3.1 - but won't work.
I even downloaded to /root on the server to upgrade...
But command say something that file was not found in local cache.. see screenshot
I had to run the following command as stated in the error message:
fix_missing_indices
Hi Christiaan,
As Vincent suggested please run the command fix_missing_indices before we start the upgrade. Looks like the server needs a database schema check prior to upgrade. Sometime it will prompt you for the same check after the upgrade as well.
I'm trying to upgrade from 8.2.4 to 8.2.4.1, and I get that same error message :
"Upgrade aborted!
Run fix_missing_indices to fix the missing indices!"
Since there's no more CLI in 8.2.4, how can I run "fix_missing_indices"?
Please open a TAC case. They should be able to help you out with this.
