Upgraded 7200 controller to Aruba Os 8.0 and cant connect anymore
  • 1.  Upgraded 7200 controller to Aruba Os 8.0 and cant connect anymore
    Posted Aug 26, 2016 07:08 PM
    We purchased two Aruba 7205 controllers to use as Master-Backup in a client´s network. I have made a very short config and then upgraded the firmware to OS 8.0 and now when trying to access the default IP that wasn´t changed (172.16.0.254) I can´t connect to the controller.
    Does the OS changes the default IP?
     When connecting through console port it stops in auto-provisioning waiting for dhcp and activate servers. If i try the mini-setup it asks me for master_switch MAC addreses and some information i dont have as this should be the master.
    2) I have read the release notes and found something I was not very clear. That mobility masters can´t handle APs directly. In this solution the client has 80 APs connected to the controllers on a VRRP config. No extra local controllers. This will not be possible anymore?
    Thanks!
  • 2.  RE: Upgraded 7200 controller to Aruba Os 8.0 and cant connect anymore
    Posted Aug 26, 2016 07:10 PM
    AOS 8 is a major change in architecture. You should consider using 6.5 or
    reach out to your Aruba SE for assistance with planning and deploying this
    new architecture.
  • 3.  RE: Upgraded 7200 controller to Aruba Os 8.0 and cant connect anymore
    Posted Aug 26, 2016 07:12 PM
    Ok, so now how can i downgrade the version if I cant connect to the controller?
  • 4.  RE: Upgraded 7200 controller to Aruba Os 8.0 and cant connect anymore
    Posted Aug 26, 2016 07:15 PM
