I was planning on upgrading our MM and cluster from 8.7.1.9 to 8.7.1.10 this weekend. However, after upgrading the MM to 8.7.1.10, it shows one of my controllers as being down. It's not down. I can still ping and access it.
I plan on doing the live upgrade process which has worked great before but I reverted the MM back to 8.7.1.9 before moving forward. It's showing up after reverting to 8.7.1.9.
Is the "down" controller a bug? Should I continue with the live cluster upgrade even though the MM says one of my controllers is down?
Nathan K
