Upgrading 5.0.1.0 to 6.3.1.6 - 3200 Controller
  • 1.  Upgrading 5.0.1.0 to 6.3.1.6 - 3200 Controller
    Posted Oct 22, 2014 04:47 PM
    I have a client that is upgrading from 5.0.1.0 to 6.3.1.6.  According to the 6.3.1.6 release notes you need to go to an intermediate version first, as shown here:
    For ArubaOS 3.x or ArubaOS 5.0.x versions earlier than ArubaOS 5.0.3.1, download the latest version of Aruba OS 5.0.4.x.
    Instead of going to 5.0.4.x we went to 5.0.3.3 and then to 6.3.1.6.  This appeared to work and our "show image version" shows that 6.3.1.6 is installed:
    Partition : 0:0 (/dev/hda1)
    Software Version : ArubaOS 6.3.1.6 (Digitally Signed - Production Build)
    Build number : 43301
    Label : 43301
    Built on : Fri Apr 18 15:00:26 PDT 2014
    Partition : 0:1 (/dev/hda2) **Default boot**
    Software Version : ArubaOS 5.0.1.0 (Digitally Signed - Production Build)
    Build number : 24398
    Label : 24398
    Built on : Sun Jun 13 23:49:08 PDT 2010
    However, it appears that it didn't really work since APs will not connect when running on 6.3.1.6.  Additionally, when accessing the GUI in 6.3.1.6 we get the following message:
    Ancillary image stored on flash is not for this release
    WARNING: An additional image upgrade is required to complete the
    installation of the AP and WebUI files. Please upgrade the boot
    partition again and reload the controller
    Using the "Upgrade Now" option from this message does not resolve the issue.  Is this a result of going from 5.0.1.0 to 5.0.3.3 instead of 5.0.4.x?  My thought was going to 5.0.3.3 put us above the 5.0.3.1 version mentioned in the Release Notes.
    Any feedback would be greatly appreciated, Thanks!
  • 2.  RE: Upgrading 5.0.1.0 to 6.3.1.6 - 3200 Controller
    Posted Oct 22, 2014 05:30 PM
    Did you upgraded the memory in the 3200 ?
    It's required to upgrade to 6.2.x and up
  • 3.  RE: Upgrading 5.0.1.0 to 6.3.1.6 - 3200 Controller
    Posted Oct 22, 2014 06:46 PM
    No, we didn't change any hardware.
    #show mem
    Memory (Kb): total: 761348, used: 274416, free: 486932
    What I see in the 6.3.1.6 guide says you need to have 40 MB free.
    #show storage
    Filesystem Size Used Available Use% Mounted on
    none 300.0M 1.7M 298.3M 1% /tmp
    /dev/hda3 392.7M 79.4M 293.1M 21% /flash
    Do you have specifics for what you are referring to?  We didn't get any errors during the upgrade regarding space/memory.
    Additionally, I've upgraded other 3200s that had 5.0.3.3 installed and was able to install 6.3.1.6 without issue.  The difference between those and these is that these started on ArubaOS 5.0.1.0.
  • 4.  RE: Upgrading 5.0.1.0 to 6.3.1.6 - 3200 Controller
    Posted Oct 22, 2014 06:49 PM
    Victor is correct, but did you reload into 5.0.3 first?  I would have expected to see that version in one of the partitions.
    The aps themselves also need to be upgraded to the intermediate version before going to 6.3.
  • 5.  RE: Upgrading 5.0.1.0 to 6.3.1.6 - 3200 Controller
    Posted Oct 22, 2014 07:26 PM
    We only did the upgrades on the Partition that has 6.1.3.6 installed, which is why you don't see the 5.0.3.3 showing up.  To be honest, I'm working with a client and I didn't complete the steps myself - so there could be something I'm missing.  For instance, I do not know if the APs were ever booted to the intermediate version first.
    Of course, that could explain why the APs won't connect.. but it wouldn't necessarily explain why the controller gets an error message.
    I did see in the 6.3.1.6 Release Notes there is a Bug ID of 95044 which gives a similar error, but they state it only occurs with 7200 series..
    95044 Symptom: All access points went down when the controller to which they were connected rebooted and an error was displayed - Ancillary image stored on flash is not for this release. This issue is resolved by writing the boot partition information to the secondary bank of the NVRAM.
    Scenario: This issue occurred when the controller rebooted due to a watchdog reset. This issue is observed only in 7200 Series controllers.
    Could this be related to having 6.1.3.6 on one partition and something as old as 5.0.1.0 on the remaining partition?
  • 6.  RE: Upgrading 5.0.1.0 to 6.3.1.6 - 3200 Controller
    Posted Oct 22, 2014 07:29 PM
    Since the release notes state if you are upgrading from something older than 5.0.3.1 you need to upgrade to 5.0.4.x first.  Could there be something missing by going to 5.0.3.3 and then to 6.3.1.6?
  • 7.  RE: Upgrading 5.0.1.0 to 6.3.1.6 - 3200 Controller
    Posted Oct 22, 2014 08:29 PM
    Follow this to fix it:
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Tutorial-How-to-fix-a-corrupt-OS/m-p/150468
    Then you need to upgrade your 3200 controller memory , contact your local Aruba team and they should able to assist you with purchasing the memory
  • 8.  RE: Upgrading 5.0.1.0 to 6.3.1.6 - 3200 Controller
    Posted Oct 23, 2014 12:30 PM
    Thanks for the information.
    Also, I'm confused about the memory. The 6.3.1.6 release notes state the following:
    Issue the show memory command to confirm that there is at least 40 MB of free memory available for an upgrade using the CLI, or at least 60 MB of free memory available for an upgrade using the WebUI. Do not proceed unless this much free memory is available. To recover memory, reboot the controller. After the controller comes up, upgrade immediately.
    Issue the show storage command to confirm that there is at least 60 MB of flash available for an upgrade using the CLI, or at least 75 MB of flash available for an upgrade using the WebUI.
    The show storage command shows:
    Based on this, we have plenty of space and we already have the 6.3.1.6 version installed, so it doesn't appear to be a memory/space issue. Can you clarify the requirements you are looking at? Additionally, the link you provided states that the 3200 doesn't support 6.4x without a memory upgrade, but I'm not trying to go to 6.4x.
  • 9.  RE: Upgrading 5.0.1.0 to 6.3.1.6 - 3200 Controller
    Posted Oct 23, 2014 02:35 PM
    The memory upgrade refers to the RAM. Do a show memory which will show you if you need to purchase. This thread will help you http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-to-Identify-differences-between-3200-and-3200XM-controller/ta-p/180516
  • 10.  RE: Upgrading 5.0.1.0 to 6.3.1.6 - 3200 Controller
    Posted Oct 23, 2014 04:01 PM
    Thanks, this is helpful.  I did run the "show mem" command earlier in the thread.  Here's the output again:
    #show mem
    Memory (Kb): total: 761348, used: 275120, free: 486228
    According to the article you posted, the 3200 would have "5" digits for FREE space and the 3200XM would have "6".  We show 6, so this should be good to go.
  • 11.  RE: Upgrading 5.0.1.0 to 6.3.1.6 - 3200 Controller
    Posted Oct 24, 2014 06:19 AM
    Label : 43301
    Label : 24398
    pdx,
    the specific error above is fixed by you upgrading the same partition again with the same version of code.  Please contact TAC to solve this issue.
