Comware
  • 1.  Upgrading 5700 - problem with step firmware
    Posted Apr 14, 2015 06:50 AM
    Hey
    Im upgrading from 5700-cmw710-boot-r2311p05.bin --> 5700-CMW710-R2416.ipe, but i get a
    "Incompatible upgrade" when running the matrix command.
    Get:
    System image: 5700-cmw710-system-r2416.bin
      Version:
      7.1.045-Release 2416
      Version compatibility list:
      7.1.045-ESS 2415
      7.1.045-ESS 2415P01
      Version dependency boot list:
      7.1.045
    But none of these firmware files are posted at: https://h10145.www1.hp.com/Downloads/SoftwareReleases.aspx?ProductNumber=JG898A&lang=en,en&cc=us,us&prodSeriesId=7268889
    as far as I can see. Wondering if anyone can help me out. What do i need to upgrade to before the latest posted firmware image.
    Regards Jon
    #5700
    #FlexFabric
    #upgrade
  • 2.  RE: Upgrading 5700 - problem with step firmware
    Posted Apr 14, 2015 09:19 AM
    Hi Jonare
    I just ran the upgrade on a R2310. Worked fine.  Dunno about that "matrix-command."
    It does upgrade from BOOTROM to version 139. (I was at 132). So it reboots again after that.
    I also patched R2416 with the system-patch-r2416h01.
    I've attached a transcript (partially*) of the console during the process. Gives you an idea . .
    *I've edited out all those (tabulated completions) and loong display outputs.
    Regards
    Attachment(s)
    txt
    5700-bootprocess.txt   703 B 1 version
  • 3.  RE: Upgrading 5700 - problem with step firmware
    Posted Apr 14, 2015 11:49 AM
    Ok thanks, I Will take a look, and try upgrading tomorow.
    As I understood it in the documentation you had to do step by step upgrade and use the matrix command to check for issues.
    When I check the version history, there is no upgrades between the two. Maybe Im to carefull for once !
