Upgrading a 7200 Cluster Firmware
  • 1.  Upgrading a 7200 Cluster Firmware
    Posted Nov 30, 2016 04:30 PM
    Hi Everyone,
    I have a cluster of two 7200 controllers ina active/passive currently running 6.4.3.9.
    what is the best way to upgrade
    1. install firmware on master and reboot
    2. install Firmware in local reboot
    and second q. is going from 6.4.3.9 to 6.5.0.3 ok
    is there a upgrade matrix i.e before going to 6.5.x.x you must be on 6.4.x.x
  • 2.  RE: Upgrading a 7200 Cluster Firmware
    Posted Nov 30, 2016 04:36 PM
    You can upgrade to/from those firmwares with no issue.
    Upload the file to both and then reboot at the same time.  Make sure you do a "backup flash" on both controllers before you reboot, just in case you have to revert...
  • 3.  RE: Upgrading a 7200 Cluster Firmware
    Posted Dec 01, 2016 04:31 AM
    I think it would loss connectivity if rebooting both controller at the same time, right?
    #AirheadsMobile
  • 4.  RE: Upgrading a 7200 Cluster Firmware
    Posted Dec 01, 2016 06:43 AM
    Yes.  You need an upgrade Window.
