Network Management
upgrading Airwave
  • 1.  upgrading Airwave
    Posted Feb 03, 2012 10:58 AM
    I have recently installed airwave, and want to upgrade it.  I see that I need to start a screen session before downloading the new os.  However when I try to putty to my airwave server using SSH, it is asking for password (I am assuming root)  I enter my admin credentials, but it fails.  What am I missing?  is there a specific command line I need to follow to access in the CLI?
    -Centurio-
  • 2.  RE: upgrading Airwave
    Posted Feb 03, 2012 11:19 AM
    You need to login with root as the username and use the password you setup during the install.  It should be the same password for the admin user.
    -Mike
  • 3.  RE: upgrading Airwave
    Posted Feb 03, 2012 11:28 AM
    thanks for the reply, this is what I got.
    login as: root
    Access denied
    root@192.168.235.200's password:
    Access denied
    Access denied
    Access denied
    Access denied
  • 4.  RE: upgrading Airwave
    Posted Feb 03, 2012 11:30 AM
    I just tried it on mine and it was the original admin password.
    Username: root
    Password: original admin password configured
    Do you recall having any other passwords?  If you can't logon you will have to do a password reset for root user.
    -Mike
  • 5.  RE: upgrading Airwave
    Posted Feb 03, 2012 11:38 AM
    The default root password is not working,  other than my gui admin password I cannot think of any other passwords.  So I am looking at a root password reset?
  • 6.  RE: upgrading Airwave
    Posted Feb 03, 2012 11:42 AM
    Did you try the admin password?  I assume you did. :)
    If you need to reset the root password, here is a thread with the steps:
    http://community.arubanetworks.com/t5/AirWave-and-Network-Management/Resetting-Airwave-Root-Password/td-p/9039
    Let me know if you are able to reset the password.
    -Mike
  • 7.  RE: upgrading Airwave
    Posted Feb 03, 2012 11:44 AM
    Yes, I tried same results.  Thanks for the help, I probably will be back once I get into the CLI concerning the upgrade.
    Thanks for the help.
    -Centurio-
  • 8.  RE: upgrading Airwave
    Posted Feb 03, 2012 11:47 AM
    Can you try it via the console instead of SSH?
