Hello ,
we have currently 7210 controller running at 6.X OS and we need to upgrade the following controller .
Kindly assist
Please start here:
https://community.arubanetworks.com/t5/Controller-Based-WLANs/ArubaOS-8-Fundamentals-Guide/ta-p/428914
Hi , Once migrated to OS8.X , Still it can be used as Master- Local Setup and terminate the APs
Are the existing license also migrated from OS6.X to OS8.X ?
You can still use Master/Local in AOS8 however if a Mobility Master is available then you should consider using Clustering instead. Take a look at the fundamentals guide, it is an excellent resource
