Aruba Apps
last person joined: 8 days ago
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
Upgrading Aruba Clearpass with Controller?
  • 1.  Upgrading Aruba Clearpass with Controller?
    Posted Nov 14, 2014 06:47 AM
    Hello all,
    I wanted to upgrade our Aruba Clearpass as well as our Controller.
    Controller version:
    Model: Aruba3600
    Version: 6.1.3.7
    Compiled: 2013-02-08 at 18:31:05 PST (build 37112) by p4build
    Clearpass:
    ClearPass Policy Manager 6.1.0.50820 on CP-VA-500 platform
    but I could not find, which I should do first, as well if I can upgrade them both without any issues since they're both in a live environment currently.
    Could someone please point me in the correct direction.
    Thank you very much in advance.
    Kind regards,
  • 2.  RE: Upgrading Aruba Clearpass with Controller?
    Posted Nov 14, 2014 07:06 AM
    You could do either , you shouldn't need to do it in order.
    But to make sure that run into issue with both systems I will suggest you do one at a time , confirm that things are working properly and then upgrade the other system.
    Backup the config on both and read the release notes .
    For the controller I suggest you install the latest 6.3.1.13 there's a lot of bug fixes
  • 3.  RE: Upgrading Aruba Clearpass with Controller?
    Posted Nov 14, 2014 07:08 AM
    Hello Fabian
    Thank you for your very quick reply.
    Can I upgrade directly to the mentioned version or do I need to take  a specific upgrade path?
    Thanks!
  • 4.  RE: Upgrading Aruba Clearpass with Controller?
    Posted Nov 14, 2014 07:24 AM
    For the controller you can go directly
    But for ClearPass what version are you trying to upgrade to ?
  • 5.  RE: Upgrading Aruba Clearpass with Controller?
    Posted Nov 14, 2014 07:25 AM
    Hello Fabian,
    I think the latest would be best?
  • 6.  RE: Upgrading Aruba Clearpass with Controller?
    Posted Nov 14, 2014 07:48 AM
    I have customers using 6.4 with no issues today but I recommend that you read the release notes and see if there's any known issues that might impact your environment
    In the release notes there's instructions on how to upgrade from your current version to 6.4
    I have attached the release notes as well.
    Attachment(s)
  • 7.  RE: Upgrading Aruba Clearpass with Controller?
    Posted Nov 14, 2014 07:51 AM
    Hello Fabian,
    Thanks alot for your help!
