Upgrading Aruba Controller 7030 from 8.3.0.1 to 8.5.0.2
  • 1.  Upgrading Aruba Controller 7030 from 8.3.0.1 to 8.5.0.2
    Posted Sep 18, 2019 11:47 AM
    Hi everybody,
    I'm not used to upgrade my controller but i want to upgrade my 7030 controller to last update.
    Can i jump directly form 8.3.0.1 to 8.5.0.2 ? Or I need a step with 8.4 ?
    Will I lose my configuration ?
    I check all my APs are compliant with 8.5.0.2. so it's ok.
    Thanks for your help.
  • 2.  RE: Upgrading Aruba Controller 7030 from 8.3.0.1 to 8.5.0.2
    Posted Sep 18, 2019 12:01 PM
    Are you looking for a live upgrade? or do you have downtime scheduled?
    If the APs support the code then go for it.
    If you have a cluster and it is a L2 connected cluster id recommend giving the live upgrade a try.
  • 3.  RE: Upgrading Aruba Controller 7030 from 8.3.0.1 to 8.5.0.2
    Posted Sep 19, 2019 07:45 PM
    Is this a standalone controller or do you have a Mobility Master? Also, before upgrading, from the controller CLI run a backup "backup flash". This will create a file flashbackup.tar.gz, which you can see from the CLI by running the "dir" command. You can copy this file to an FTP/TFTP/SCP server, but you don't have to. I will sit there on your controller until you delete it.
