The 7005 controller image was deleted does not relate to upgrading from 6.4 to 8.10.
Can you open a new discussion for this separate topic?
Original Message:
Sent: Dec 09, 2022 10:01 AM
Subject: UPGRADING ARUBAOS 6.4.4.20 TO ARUBAOS 8.10.0.5
Hi everyone, our 7005 controller image was deleted. How can I restore it or install a new image, please?
Original Message:
Sent: Dec 08, 2022 06:20 PM
Hi Mcelleja,
Aruba AOS6 and AOS8 have a different architecture. Upgrading from AOS6 to AOS8 means the controller become factory default and you have to re-built your configuration manually. See also the migration guide here.
If your not familiar with the process ask your local Aruba Partner to assist you.
Marcel Koedijk | MVP Expert 2022 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
Original Message:
Sent: Dec 07, 2022 12:29 PM
Hi, team.
I need to upgrade ARUBAOS 6.4.4.20 to ARUBAOS 8.10.0.5 on two HA wifi controller 7030 and AP205.
I cant find any upgrade path, may a have to upgrade 6.4.4.20 to an specific version before to upgrades to 8.10.0.5? ore can i upgrade directly to 6.4.4.20 to 8.10.0.5?
Could somebody help me please?
Goodby
