Upgrading Clearpass from 6.3.1 to 6.3.6
  • 1.  Upgrading Clearpass from 6.3.1 to 6.3.6
    Posted Nov 24, 2015 02:18 AM
    Hi
    We are trying to upgrade the Clearpass agent on Client systems / PCs from 6.3.1 to 6.3.6 with SCCM (even tried with GPO) , but it fails after unsintalling the old version, below is the log that says it's uninstalling the old version
    if: ClearPassUSHARemediate.exe,0 is not running
    Calling uninstaller since UNINSTALL=0 and UPGRADE=1
    Same time we are able to install the agent manually and this time it's not uninstalling the old version, but proceeds with the installation as seen below
    proceeding for install
    Call: 3067
    Has anyone faced similar issue?
    Thanks in advance
  • 2.  RE: Upgrading Clearpass from 6.3.1 to 6.3.6
    Posted Dec 20, 2015 09:13 AM
    you better try here: http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/bd-p/aaa-nac-guest-access-byod
    no personal experience with (un)installing the clearpass agent with sccm or gpo unfortunately.
