Upgrading IAP-305 and -315
  • 1.  Upgrading IAP-305 and -315
    Posted Mar 06, 2020 03:20 PM
    We're currently running version 8.4.0.4 on our IAPs - the 'new version available' message indicates that 8.6.0.2 can be installed. The question I have is: can you upgrade straight from 8.4 to 8.6 or do you have to do an upgrade to 8.5 first? The reason I ask is that I tried going directly from 8.4.0.4 to 8.6.0.2 using AirWave and the download to the IAP never took place, so I'm wondering if you can't do that.
  • 2.  RE: Upgrading IAP-305 and -315
    Posted Mar 06, 2020 05:12 PM
    you can go directly to 8.6.0.2 for those APs.
  • 3.  RE: Upgrading IAP-305 and -315
    Posted Mar 09, 2020 08:03 AM
    Great - thank you!
