Hey Guys
I m facing an issue with 620 , When i upgrade it form AOS 6.4.0.3 to 6.4.1 it keeps give me errors such as:
- upgrade from USB : no file found
- Upgrade TFTP : cant verify the version
- Local option is dimmed
Can any body help me
Are you sure you are using the correct upgrade file? Which one are you using?
I solved the Issue , by Booting with Partion 1 and upgrade Partion 0
