Wired Intelligent Edge
Uplink Configuration HP Core and Aruba 7205 WLC
  • 1.  Uplink Configuration HP Core and Aruba 7205 WLC
    Posted Jan 09, 2020 11:05 AM
    hi,
    i have 2 x HP Core Switches (IRF Configured, Redundancy is workign fine)
    and 2 x Aruba 7205 WLC connected to this HP Core with port-0 and port-1 connected to Core
    below is the configuration at Core
    interface Bridge-Aggregation60
    description CONNECTED_TO_ARUBA_WLC-01
    port link-type trunk
    port trunk permit vlan 2 to 60
    link-aggregation mode dynamic
    interface GigabitEthernet1/1/0/23
    port link-mode bridge
    description CONNECT_TO_ARUBA_WLC-01
    port link-aggregation group 60
    interface GigabitEthernet1/1/0/24
    interface Vlan-interface60
    ip address 10.50.60.254 255.255.255.0
    dhcp server apply ip-pool dhcp-vlan60
    interface Vlan-interface24
    ip address 10.50.27.254 255.255.255.0
    dhcp server apply ip-pool dhcp-vlan24
    dhcp server ip-pool dhcp-vlan24 extended
    network ip range 10.50.24.11 10.50.27.250
    network mask 255.255.252.0
    gateway-list 10.50.27.254
    dns-list 10.1.1.250
    domain-name abc.com
    is this configuration will work fine  ???
    i can access the WLC now ..but clients can not get ip address
    please help
    regards,
    Anvar
  • 2.  RE: Uplink Configuration HP Core and Aruba 7205 WLC
    Posted Jan 10, 2020 08:01 AM
    If you don't have the basics working, it is really hard to help you in this forum with limited information. It's probably something simple, and if you work with your partner or Aruba Support it is probably much faster to get to a solution and working configuration.
    From what I have seen in your different posts it can be the uplink configuration from the controller, the port and VLAN trusts, LACP, to start with. With access to the system for your partner or Support, it is probably easy to run the relevant commands to find and solve the issue.
