Uplink VLAN?
  • 1.  Uplink VLAN?
    Posted Feb 28, 2018 04:32 AM
    Uplink VLANs in the documentation refer to tagging management frames only - but would this apply to other traffic as well?
    We need to deploy an AP-203R for a residential internet connection, with a PPPoE uplink, which must be tagged with VLAN 10. Is this possible?
  • 2.  RE: Uplink VLAN?
    Posted Mar 05, 2018 04:35 PM
    As far as i could research, PPoE should only allow untagged frames and not tagged frames. Is that not the case? Can you provide some proof to support your argument please.
  • 3.  RE: Uplink VLAN?
    Posted Mar 05, 2018 11:40 PM
    In New Zealand most ISPs provision a GPON connection with a tagged UNI, which we establish a PPPoE session in :)
  • 4.  RE: Uplink VLAN?
    Posted Feb 26, 2020 11:49 AM
    In Brazil, ISP provide a GPON connection with a marked UNI, in which we establish a PPPoE session with V-Lan 10 for internet, V-lan 20 for telephone and V-Lan 30 for television.
    I will only use the internet, so I need to put the Iap-205H Up link in POE and V-Lam 10.
    Any help is good.
  • 5.  RE: Uplink VLAN?
    Posted Apr 06, 2020 05:49 PM
    Can anyone help with this problem?
  • 6.  RE: Uplink VLAN?
    Posted Apr 07, 2020 04:43 AM
    This is an old thread. I recommend opening a new one and describing your issue in detail.
