Upload content for use in captive portal
  • 1.  Upload content for use in captive portal
    Posted Nov 29, 2012 10:43 AM
    When I try to upload new content to use in our customized captive portal I run into the following error.
    System has low free memory and/or low free disk space. Please delete unwanted files by accessing WebUI Maintenance > File > Delete Files, reload the controller to recover free memory and try uploading the image again. If it fails again, try other upgrade options.
    This error is pretty self-explanatory.. you'd say :)
    What command can I use to determine wether dispace and/or memory is the issue?
  • 2.  RE: Upload content for use in captive portal
    Posted Nov 29, 2012 02:18 PM
    Please try the following commands.
    (3600) #show memory
    Memory (Kb):
    total: 1541408, used: 285068, free: 1256340
    (3600) #show storage
    Filesystem Size Used Available Use% Mounted on
    none 300.0M 3.2M 296.8M 1% /tmp
    /dev/hda3 392.7M 111.7M 260.7M 30% /flash
    (3600) # dir
  • 3.  RE: Upload content for use in captive portal
    Posted Nov 30, 2012 03:47 AM
    (ZMARUBA01) #show memory
    Memory (Kb): total: 354376, used: 297832, free: 56544
    (ZMARUBA01) #show storage
    none                    300.0M      3.8M    296.2M   1% /tmp
    /dev/hda3               392.7M    145.6M    226.8M  39% /flash
    (ZMARUBA01) #
    Seems to be enough mem/storage.. right?
  • 4.  RE: Upload content for use in captive portal
    Posted Dec 03, 2012 03:42 AM
    Monday mornin' bump
  • 5.  RE: Upload content for use in captive portal
    Posted Dec 03, 2012 03:50 AM
    - What controller platform is this?
    - What verson of ArubaOS?
    - How big is the content you are trying to upload?
    Can you try typing "tar crash" at the commandline and copying off and deleting the crash.tar file and trying again?
    Can you type "dir" to see if you have any file that you might not be using there?
  • 6.  RE: Upload content for use in captive portal
    Posted Dec 03, 2012 10:32 AM
    Creating and deleting the crash tar did the trick, tnx.
  • 7.  RE: Upload content for use in captive portal
    Posted Dec 05, 2012 09:30 AM
    Seems to be a temp fix.
    Same problem again, cant upload any custom content (html files)..
    Any ideas?
  • 8.  RE: Upload content for use in captive portal
    Posted Jan 10, 2013 10:52 AM
    Bump
  • 9.  RE: Upload content for use in captive portal
    Posted Jan 10, 2013 02:57 PM
    Please open a support case to get to the bottom of this.  I can say that I have not seen your issue, but others might have.
  • 10.  RE: Upload content for use in captive portal
    Posted Dec 09, 2014 10:38 AM
    hey,
    please enveekaa have you found any solution to this issue, i got the same probleme with a 7030 controller
  • 11.  RE: Upload content for use in captive portal
    Posted Dec 13, 2014 12:34 PM
    hay any update :)
  • 12.  RE: Upload content for use in captive portal
    Posted Dec 14, 2014 07:57 AM
    for the reference
    according to the TAC the issue was resolved in the version 6.4.2.3 , indeed we found in the release note of the version 6.4.2.3 that the  bug was resolved.
    I'll try it , I hope it'll work
