UPN authentication with clearpass and active directory
This thread has been viewed 40 times
  • 1.  UPN authentication with clearpass and active directory
    Posted Sep 24, 2014 09:18 AM
    I have Clearpass authenticating iPhones and Androids.  I need to pass the UPN authentication from Clearpass to Active Directory to have Clearpass make a decision.  Both phones authenticate via a certificate.
    My Android phones authenticate with the AD SAM username. EX ncci/ncdlt. The iPhones try to authenticate with the UPN. EX daniel_tominovich@ncci.com.  The Androids work and the iPhones do not.
    How do I get Clearpass to pass the UPN on to AD for authentication?
  • 2.  RE: UPN authentication with clearpass and active directory
    Posted Sep 24, 2014 09:20 AM
    Under the authentication tab (at the bottom), try stripping the domain using the "user:@" syntax.
  • 3.  RE: UPN authentication with clearpass and active directory
    Posted Sep 24, 2014 09:49 AM
    I tried that and it had no effect on the authentication.
  • 4.  RE: UPN authentication with clearpass and active directory
    Posted Sep 24, 2014 01:16 PM
    Changing from this:
    (&(objectClass=user)(sAMAccountName=%{Authentication:Username}))
    to this:
    (|(&(objectClass=user)(sAMAccountName=%{Authentication:Username}))(&(objectClass=user)(userPrincipalName=%{Authentication:Username})))
    was the fix.
  • 5.  RE: UPN authentication with clearpass and active directory
    Posted Sep 21, 2018 04:37 AM
    Hi!
    Many thanks for this authentication filter - still best choice for this scenario.
    I've added the AD badPWDCount to the filter so that Clearpass does not pass wrong credentials to AD after 4 tries:
    (&(|(&(objectClass=user)(sAMAccountName=%{Authentication:Username}))(&(objectClass=user)(userPrincipalName=%{Authentication:Username})))(!(badPwdCount>=4)))
    With kind regards
    Manfred M.
  • 6.  RE: UPN authentication with clearpass and active directory
    Posted Aug 14, 2020 01:41 PM
    Griaß di Manfred!
    Aged post but - thank you for sharing that filter combination.
    Saved me time
  • 7.  RE: UPN authentication with clearpass and active directory
    Posted Aug 10, 2022 05:32 AM
    i need help with OU i add the:
    for username and work great, now i want add ou for department name any help ?
    thank you
  • 8.  RE: UPN authentication with clearpass and active directory
    Posted Aug 10, 2022 07:55 AM
    You responded to an old discussion and your question is unrelated to the topic (OU and UPN are mutually exclusive).
    Please open a new post and explain what you want to achieve.
