USB to serial (db9)
  • 1.  USB to serial (db9)
    Posted Jun 08, 2012 01:19 AM
    I have just received the Aruba demo kit C - The problem is, my laptop does not support a db9 serial connection,so can't run CLI I am running windows 7 (64 bit) . There seem to be many USB to serial adapters out there, and many good and bad reviews. Does anyone have any recommendations?
  • 2.  RE: USB to serial (db9)
    Posted Jun 10, 2012 12:00 AM
    Try one from IOGear or Belkin.  I've used both in the past and I've had success with multiple OS.
    -Mike
  • 3.  RE: USB to serial (db9)
    Posted Jun 10, 2012 12:07 AM
    Two comments/recommendations for you :
    1) Stay away from USB cables that require the Prolific drivers.  They cause tons of  Blue Screen issues.
    and
    2) Go for a $12  FTDI style USB-serial cable.   Reliable as it comes, and self installing drivers built-in (always nice) for windows.    PLUS not one single blue screen :)
    3 Cheers for FTDI !
  • 4.  RE: USB to serial (db9)
    Posted Jun 13, 2012 10:23 PM
    Mike, thanks for the input,
  • 5.  RE: USB to serial (db9)
    Posted Jun 13, 2012 10:24 PM
    Thanks, I will give this route a shot. Agreed, USB seems to be problematic.
  • 6.  RE: USB to serial (db9)
    Posted Jun 15, 2012 03:54 PM
    Maybe you could give a try at http://ser2net.sourceforge.net/
    hava linux box with 2 onboard serial and profilic usb adapter running....
    with junos no problem, also with arubaos.
    Regards
    Piccolo
