use AP-225 with IAP-207 as controller
  • 1.  use AP-225 with IAP-207 as controller
    Posted Jan 24, 2023 03:28 PM
    Good morning
    I have some AP-225 (JW174A) which occupy a controller, it is planned to acquire an IAP-207 (JX954A) do you know if this is possible?
    Since it strikes me, that the IAP-207 has a RW in its nomenclature.
    Greetings
  • 2.  RE: use AP-225 with IAP-207 as controller
    Posted Jan 24, 2023 05:36 PM
    They would both have to be IAPs in the same regulatory domain to work together, unfortunately.
  • 3.  RE: use AP-225 with IAP-207 as controller
    Posted Jan 26, 2023 11:56 AM
    Not fully sure what you want to know.
    JW174A = AP-225 Campus Access point, which indeed requires a controller to operate.
    IAP-207-RW = Rest-of-world unified AP, which can run as Aruba Instant (controller-less or built-in virtual controller) or as campus AP.
    If you have enough licenses on your controller, and the controller runs a firmware version that supports the AP-207, you can convert an IAP-207-RW to campus mode and add that to the controller (or replace the AP-225).
    Best to work with your Aruba Partner if you are unsure.
