Use API to fetch Fingerprint Dictionary
  • 1.  Use API to fetch Fingerprint Dictionary
    Posted Jan 29, 2018 11:32 AM
    Does the CPPM API have the capability to fetch a list of the entire fingerprint dictionary? I can export it manually as an XML file, but that is laborious and a manual process. I'm looking for a method to fetch that data via a script. Thanks!
  • 2.  RE: Use API to fetch Fingerprint Dictionary
    Posted Jan 29, 2018 11:37 AM
    GET /fingerprint
  • 3.  RE: Use API to fetch Fingerprint Dictionary
    Posted Jan 29, 2018 11:47 AM
    Thanks for the quick reply - can you elaborate a bit? I tried a GET against https://<cppm>/fingerprint and I'm redirected to the Guest manager?
  • 4.  RE: Use API to fetch Fingerprint Dictionary
    Posted Jan 29, 2018 11:57 AM
    It's part of the standard REST API.
    https://fqdn/api/fingerprint
  • 5.  RE: Use API to fetch Fingerprint Dictionary
    Posted Jan 29, 2018 12:04 PM
    I'm getting a 403 forbidden error. When I attempt to browse to https://<fqdn>/api, I'm getting an error: An error occurred during execution; please try again later.
  • 6.  RE: Use API to fetch Fingerprint Dictionary
    Posted Jan 29, 2018 12:27 PM
    Did you pass your access token with the request?
  • 7.  RE: Use API to fetch Fingerprint Dictionary
    Posted Jan 29, 2018 12:31 PM
    Right after I sent my last reply, yes...working as expected now. Sorry for the confusion and thanks!
