Use both ethernet interfaces on IAP 325.
  • 1.  Use both ethernet interfaces on IAP 325.
    Posted Jun 07, 2017 12:28 AM
    How do I use both interfaces for higher bandwidth / redundancy on IAP 325. We yet to receive controller 7010.
    I would like IAP 325 to use both ethernet ports.
  • 2.  RE: Use both ethernet interfaces on IAP 325.
    Posted Jun 07, 2017 01:19 AM
    You need to configure LACP on the switch.
    If already not enabled, you can use below document to enable LACP on the IAP:
    https://community.arubanetworks.com/t5/Controller-less-WLANs/LACP-configuration-support-on-IAP/ta-p/267467
  • 3.  RE: Use both ethernet interfaces on IAP 325.
    Posted Jun 07, 2017 01:25 AM
    Do I need to connect both ports on PoE or only one would be fine on IAP?
  • 4.  RE: Use both ethernet interfaces on IAP 325.
    Posted Jun 07, 2017 02:02 AM
    One should be fine. Instead of POE, consider using POE+ else your AP will work in restricted mode.
  • 5.  RE: Use both ethernet interfaces on IAP 325.
    Posted Jun 07, 2017 02:10 AM
    We are using injectors from Aruba only. adapter says 55V, 0.6A.
    I believe its PoE+ only..
  • 6.  RE: Use both ethernet interfaces on IAP 325.
    Posted Jun 07, 2017 02:20 AM
    PowerDsine power injectors come with both 802.3at and af models. Hope you have got at model.
  • 7.  RE: Use both ethernet interfaces on IAP 325.
    Posted Jun 07, 2017 02:23 AM
    It's Microsemi PD-9001GR/AT/AC
    Online information says, its PoE+ .. :)
    Let me try out configuration and will update thread.
  • 8.  RE: Use both ethernet interfaces on IAP 325.
    Posted Jun 07, 2017 11:08 AM
    Good. No restrictions with that injector.
