Is there a way to modify a port that is being authenticated on from a switch port to a trunk port.
Can you send a COA or command through SNMP or SSH to modify the port based on the authenticator?
I have a wireless AP that is taken to other places and plugged in. It will authenticate using 802.1x without issue, but since the port is a switch port, the AP will not be able to use all of the vlans configured on it. If I could change it to be a trunk port then it would work as designed. Its not a problem for the ports that are mounted in places, just the ones that move around.
