Use GuestUser:SponsorName with LDAP
  • 1.  Use GuestUser:SponsorName with LDAP
    Posted Apr 21, 2021 06:32 PM
    How can I get GuestUser:SponsorName to work with LDAP queries, under Policy Manager?
    I want to block all mac track devices if the Sponsor user account is disabled or blocked.
    I can see GuestUser:sponsor_email, but am unable to use the GuestUser:sponsorname / sponsor username.
    Ricardo Duarte
  • 2.  RE: Use GuestUser:SponsorName with LDAP
    MVP GURU
    Posted Apr 27, 2021 07:54 AM
    Hi Ricard,
    Do you have add do_ldap... field ?
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Use GuestUser:SponsorName with LDAP
    Posted Apr 27, 2021 12:50 PM
    Yes, I do alread have that.
    The problem is not inside "Guest". After registration, I can't query LDAP under Tips Services to do a real-time check for ldap account.
    Because I can't get ClearPass to make queries to LDAP using GuestUser:sponsorname.
    To make it somehow clear, what I want to do is to have an LDAP Authentication source that uses the following filter:
    (&(objectClass=user)(sAMaccountName=%{GuestUser:sponsorname})
    But ClearPass does not fill the GuestUser:sponsorname in the query.
    It does work if I use:
    (&(objectClass=user)(sAMaccountName=%{GuestUser:sponsor_email})
    But for some particular reason, this query will not work for me in my scenario. I need to query by sponsorname.
    Ricardo Duarte
  • 4.  RE: Use GuestUser:SponsorName with LDAP
    MVP GURU
    Posted Apr 27, 2021 03:53 PM
    It is better to open a issue on TAC...
